Zum Hauptinhalt wechseln
Asus Z54C-JS31 WiFi Card Replacement
Was du brauchst
  1. Asus Z54C-JS31 WiFi Card Replacement, Battery: Schritt 1, Bild 1 von 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: Schritt 1, Bild 2 von 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: Schritt 2, Bild 1 von 2 Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: Schritt 2, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 WiFi Card Replacement: Schritt 3, Bild 1 von 2 Asus Z54C-JS31 WiFi Card Replacement: Schritt 3, Bild 2 von 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: Schritt 4, Bild 1 von 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: Schritt 4, Bild 2 von 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: Schritt 4, Bild 3 von 3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  5. Asus Z54C-JS31 WiFi Card Replacement: Schritt 5, Bild 1 von 3 Asus Z54C-JS31 WiFi Card Replacement: Schritt 5, Bild 2 von 3 Asus Z54C-JS31 WiFi Card Replacement: Schritt 5, Bild 3 von 3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
Abschluss
Mark DeSimone
801 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 1,425
