Zum Hauptinhalt wechseln
Asus Z54C-JS31 Display Replacement
Was du brauchst
  1. Asus Z54C-JS31 Display Replacement, Battery: Schritt 1, Bild 1 von 3 Asus Z54C-JS31 Display Replacement, Battery: Schritt 1, Bild 2 von 3 Asus Z54C-JS31 Display Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Display Replacement, Display: Schritt 2, Bild 1 von 3 Asus Z54C-JS31 Display Replacement, Display: Schritt 2, Bild 2 von 3 Asus Z54C-JS31 Display Replacement, Display: Schritt 2, Bild 3 von 3
    • Open up the laptop and locate the two circular stickers at the bottom corners of the display.
    • Use a pair of tweezers to remove the two black stickers covering the screws.
    • Using a Philips #000 screwdriver, remove the two 9mm screws.
  3. Asus Z54C-JS31 Display Replacement: Schritt 3, Bild 1 von 2 Asus Z54C-JS31 Display Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to pop off the plastic border around the display.
  4. Asus Z54C-JS31 Display Replacement: Schritt 4, Bild 1 von 3 Asus Z54C-JS31 Display Replacement: Schritt 4, Bild 2 von 3 Asus Z54C-JS31 Display Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 9mm screws from the top corners of the display with a Phillips #000 screwdriver.
    • Carefully lift the display out and place the screen face down on the keyboard.
  5. Asus Z54C-JS31 Display Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the display cable connector attached to the display.
Abschluss
Mark DeSimone
801 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 142
