Zum Hauptinhalt wechseln
Acer Aspire 4520-5464 WiFi Wireless Card Replacement
Was du brauchst
  1. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: Schritt 4, Bild 1 von 2 Acer Aspire 4520-5464 WiFi Wireless Card Replacement, WiFi Wireless Card: Schritt 4, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the two 0.5mm screws from the smallest panel on the back of the computer.
    • Set the screws aside.
    • Lift up the panel using the indent located on the left side of the panel.
  5. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Remove both the black and white wires by pinching the brass connectors and pulling up.
  6. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 0.5mm Phillips #1 black screws located on the WiFi card.
  7. Acer Aspire 4520-5464 WiFi Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • Lift the WiFi card on the left side to remove it.
Abschluss
To reassemble your device, follow these instructions in reverse order with a new WiFi wireless card.
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,028
