Zum Hauptinhalt wechseln
Acer Aspire 4520-5464 Graphics Card Replacement
Was du brauchst
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 2, Bild 2 von 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 3, Bild 1 von 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: Schritt 4, Bild 1 von 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: Schritt 4, Bild 2 von 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: Schritt 4, Bild 3 von 3
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 6, Bild 1 von 1
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 4520-5464 Graphics Card Replacement: Schritt 7, Bild 2 von 2
    • Lift up the heat sink line and remove the graphics card.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 2,381
