Einleitung
This guide will show you how to replace or upgrade the Graphics Card of an Acer Aspire 4520-5464 laptop. The graphics card allows graphics to be displayed on the screen of the laptop.
Was du brauchst
Shut down the computer and disconnect all external devices and cables.
Flip the computer over.
Ensure that the battery compartment lock tab is in the unlocked position.
Slide the sliding black tab away from the battery compartment.
The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
Lift up the panel from the indent located on the right side.
Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
