Zum Hauptinhalt wechseln
Acer Aspire 4520-5464 Keyboard Replacement
Was du brauchst
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 4520-5464 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: Schritt 5, Bild 1 von 2 Acer Aspire 4520-5464 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: Schritt 6, Bild 1 von 2 Acer Aspire 4520-5464 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 4520-5464 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
Abschluss
To reassemble your device, follow these instructions in reverse order using your new keyboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 605
