Zum Hauptinhalt wechseln
HP Pavilion 15-au123cl CMOS Battery Replacement
Was du brauchst
  1. HP Pavilion 15-au123cl CMOS Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 4, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 1 von 2 HP Pavilion 15-au123cl CMOS Battery Replacement, CMOS Battery: Schritt 6, Bild 2 von 2
    • The CMOS battery is located toward the middle left area of the motherboard.
    • Using the spudger, lift the CMOS battery out of its plastic casing.
  7. HP Pavilion 15-au123cl CMOS Battery Replacement: Schritt 7, Bild 1 von 1
    • Fully remove the CMOS battery from the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S13-G3, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 29
Letzte 30 Tage: 155
Insgesamt: 23,933
