Zum Hauptinhalt wechseln
HP G60-443CL Hard Drive Replacement
Was du brauchst
  1. HP G60-443CL Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • The battery can then be pulled out of its compartment by hand.
  5. HP G60-443CL Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Once the battery has been removed, locate the 5mm Phillips #0 screws on the bottom right panel.
    • Remove the 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
    • Next, remove the panel that was attached to the screws, leaving the hard drive exposed.
  6. HP G60-443CL Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • After the panel has been removed, use the screwdriver to remove the three 3mm Phillips #0 screws attached to the hard drive.
  7. HP G60-443CL Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Once the screws attached to the hard drive are removed, you will be able to take the hard drive out of the compartment.
Abschluss
Larissa Moreno-Trejo
101 Reputation
1 Anleitung geschrieben
Baylor, Team S8-G7, Johnson Fall 2017 Mitglied von Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 970
