Einleitung
The guide will show you how to remove the battery from the laptop. The removal of the battery is necessary to do any work inside the laptop for safety purposes.
Was du brauchst
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
Disconnect the battery connector from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
