Zum Hauptinhalt wechseln
Lenovo Edge 2-1580 Storage Replacement
Was du brauchst
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Edge 2-1580 Storage Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: Schritt 2, Bild 1 von 2 Lenovo Edge 2-1580 Storage Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: Schritt 3, Bild 1 von 3 Lenovo Edge 2-1580 Storage Replacement: Schritt 3, Bild 2 von 3 Lenovo Edge 2-1580 Storage Replacement: Schritt 3, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: Schritt 5, Bild 1 von 2 Lenovo Edge 2-1580 Storage Replacement, Hard drive: Schritt 5, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: Schritt 6, Bild 1 von 2 Lenovo Edge 2-1580 Storage Replacement: Schritt 6, Bild 2 von 2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Storage Replacement: Schritt 7, Bild 1 von 2 Lenovo Edge 2-1580 Storage Replacement: Schritt 7, Bild 2 von 2
    • Carefully, using your hand, remove the hard drive from the laptop.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S14-G1, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - Antwort
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 4,083
