Zum Hauptinhalt wechseln
iON SnapCam 1045 Wearable HD Video Camera Battery
Was du brauchst
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: Schritt 1, Bild 1 von 1
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: Schritt 2, Bild 1 von 1
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: Schritt 3, Bild 1 von 1
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: Schritt 4, Bild 1 von 2 iON SnapCam 1045 Wearable HD Video Camera Battery: Schritt 4, Bild 2 von 2
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Olakunle
102 Reputation
1 Anleitung geschrieben
IUPUI, Team S3-G3, Wilson Fall 2017 Mitglied von IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 698
