Einleitung
In this part of the guide I am going to tutor you on how to replace the camera motherboard.
Was du brauchst
Detach the magnetic clip from the bottom of the camera.
The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
Once again use the spudger to gently open the encasement.
The Battery can be safely detached and replaced.
To get to the motherboard, safely lift the battery to expose an Aluminium plate that shields and holds the motherboard in place.
The plates are held down by four Phillips 0.008 mm screws on all four corners. Use a Phillips head #000 to safely loosen the screws.
To replace the motherboard gently insert a plastic opening tool into one end and lift up.
