Was du brauchst
flip the computer over and remove the 12 philips 0 screws this will make the keyboard and trackpad part free
then unscrew the two philips 0 screws guarding the 2 RAM boards
you can remove the 2 RAM boards by lifting them up
here we have two beautiful RAM boards
by unscrewing these 2 star screws size 6 we can lift the hard disk plate.
unscrew the hard disk screws
and use the spudger to slide the hard disk out
pull it up and put it aside
slide the two plastic pieces holding the battery
and pull it out
you will have to take all these silver philips 0 screws
remove the 2 philips 0 screws and get the keyboard out with a spudger
lift the black plastic and pull the cable out
follow the same process to disconnect the trackpad, button and lights.
you will end up with something like this
you have to take this screw located on the RAM boards connector
use a spudger to lift the top off, go all around the laptop and you'll get it off
It looks really beautiful!
this is not a step I am not going deeper into this so I don't break anything you can go if you want.
the inside contains
two speakers
one cooler
ports
screen connector
and a giant interesting motherboard
oh and don't forget about the memory card reader
here we disconnect the battery slot
and we get the card reader connector out
such as the screen
remove the rest of the cables
remove the mother board screws
the screen connector is secured by 2 philips 0 screws
if you did what I did you will end up like this
I don't want to go deeper because I don't want to take the risk of breaking or damaging the computer
I will give it an 8/10
after removing the screws everything is easy to remove
the top, bezels and keyboard come easy off
some of the cables and components are fragile with makes it harder to remove
the track pad is covered with a sticky plastic with makes it harder to tear down
any components that are not well connected can make the computer not function well.
the opening tools are there if you want to disconnect some cables that are hard to disconnect
3 Kommentare
So you took the HDD out before the battery… but you turned off the computer for safety reasons.
for everyone that was thinking I started the teardown with out removing the battery I took the battery out before starting then i showed how to remove it later but it was not in all the time
