Zum Hauptinhalt wechseln
Asus X540S notebook PC Hard drive Replacement
Was du brauchst
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S notebook PC Hard drive  Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S notebook PC Hard drive  Replacement: Schritt 3, Bild 1 von 3 Asus X540S notebook PC Hard drive  Replacement: Schritt 3, Bild 2 von 3 Asus X540S notebook PC Hard drive  Replacement: Schritt 3, Bild 3 von 3
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
  3. Asus X540S notebook PC Hard drive  Replacement, Hard drive: Schritt 4, Bild 1 von 2 Asus X540S notebook PC Hard drive  Replacement, Hard drive: Schritt 4, Bild 2 von 2
    • Remove the one Philips #1 screw.
    • Slide the hard drive out.
  4. Asus X540S notebook PC Hard drive  Replacement: Schritt 5, Bild 1 von 2 Asus X540S notebook PC Hard drive  Replacement: Schritt 5, Bild 2 von 2
    • Remove the four Philips #1 screws.
Abschluss
18 weitere Nutzer:innen haben diese Anleitung absolviert.
Padraic Hoselton
4.180 Reputation
12 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.521 Anleitungen geschrieben
7 Kommentare
Looks simple enough Padraic. Thanks. Does a new install of win10 come already copied in a new HDD? Would this replacement be and different if I used a digital drive? (My old hd failed and I have no system).
sludge - Antwort
After installing an OEM replacement HDD in my x540, I bought a flash drive on Amazon for$10 that rebooted my Windows 10 and it's working like a brand new machine.
I believe the product key for windows 10 is embedded in motherboard.
F S -
F S - Antwort
Hi … How can a flashdrive reboot a Win10 on a new SDD /HDD ? A Windows flash drive contains a Win10 bootable ISO ?
On Amazon, I found flash drives with a product key but I don’t know where the new installation can be done from if there is no ISO on it …
(I have a x540 with a dead HDD …)
gnogno35 -
And thank you Padraic
F S - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 60
Insgesamt: 13,850
