Zum Hauptinhalt wechseln
Samsung PL20 LCD Replacement
Was du brauchst
  1. Samsung PL20 LCD Replacement, LCD: Schritt 1, Bild 1 von 3 Samsung PL20 LCD Replacement, LCD: Schritt 1, Bild 2 von 3 Samsung PL20 LCD Replacement, LCD: Schritt 1, Bild 3 von 3
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: Schritt 2, Bild 1 von 3 Samsung PL20 LCD Replacement: Schritt 2, Bild 2 von 3 Samsung PL20 LCD Replacement: Schritt 2, Bild 3 von 3
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: Schritt 3, Bild 1 von 3 Samsung PL20 LCD Replacement: Schritt 3, Bild 2 von 3 Samsung PL20 LCD Replacement: Schritt 3, Bild 3 von 3
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
781.160 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
32 Mitglieder
530 Anleitungen geschrieben
Ein Kommentar
Great help! Screen replaced no problem. Thank you
EE61 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 3,490
