Was du brauchst
Lift the latches and disconnect the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable from the system board.
Remove the screws that secure the palm-rest assembly to the computer base.
Lift the computer base slightly and push the palm-rest assembly through the slot on the computer base to release the tabs on the palm-rest assembly.
Turn the computer over and open the display as far as possible.
Using a plastic scribe, pry up along the edges of the palm rest assembly.
Gently lift the palm-rest assembly and turn it over.
Peel the tape that secures the power-button cable to the system board.
Disconnecting the power-board cable from the system board.
Lift the palm-rest assembly off the computer base.
Replace the touch pad.
Replace the keyboard.
Replace the status-light board.
Replace the power-button board.
Connect the power-button cable to the system board.
Adhere the tape that secures the power button cable to the system board.
Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the computer base.
Align the palm-rest assembly on the computer base and snap it into place.
Replace the screws that secure the palm-rest assembly to the computer base.
Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable into their respective connectors and press down the latches to secure the cables to the system board.
