Zum Hauptinhalt wechseln
LG G Vista Motherboard Replacement
Was du brauchst
  1. LG G Vista Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the device is powered off.
  2. LG G Vista Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
  5. LG G Vista Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard shell covering the motherboard.
  6. LG G Vista Motherboard Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
  7. LG G Vista Motherboard Replacement: Schritt 7, Bild 1 von 2 LG G Vista Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Use the tweezers to remove the four connectors as well as the back camera.
    • Be careful not to directly touch the camera lenses.
  8. LG G Vista Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Lift up and remove the motherboard from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 467
