Einleitung
If your motor stops working this guide will show you how to replace it. Previous disassembly of the vacuum must already be done in order to get to the motor.
Was du brauchst
Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
Lift the brushroll cover upward.
Flip the device over so that the bottom is face up.
Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
Two 14 mm Torx screws
Two 16 mm Torx screws
Four 21 mm Torx screws
Push inward on the top of the filter grille where it says "Push."
Lift the filter grille upward.
Remove the four screws by rotating counter-clockwise:
One 12 mm screw with a T10 Torx screwdriver
Three 14 mm screw with a T15 Torx screwdriver
Remove the grey filter plate by simply lifting upward.
Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
Remove two 16mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
Remove the belt-assembly unit by pulling the belt-assembly unit away from the motor.
Rotate the motor unit over so that the wires are exposed.
Cut wires with cutting pliers to release the motor.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
