Zum Hauptinhalt wechseln
HP Pavilion 13-P110NR Keyboard Replacement
Was du brauchst
  1. HP Pavilion 13-P110NR Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the two rubber feet closest to the black hinge.
  2. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 13-P110NR Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 3, Bild 1 von 1
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Lift the metal brace and remove it from the device.
  5. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion 13-P110NR Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  6. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 6, Bild 1 von 2 HP Pavilion 13-P110NR Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  7. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  8. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 8, Bild 1 von 3 HP Pavilion 13-P110NR Keyboard Replacement: Schritt 8, Bild 2 von 3 HP Pavilion 13-P110NR Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  9. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  10. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the metal plate to reveal the keyboard.
  11. HP Pavilion 13-P110NR Keyboard Replacement: Schritt 11, Bild 1 von 2 HP Pavilion 13-P110NR Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the keyboard from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 312
