Zum Hauptinhalt wechseln
Shark Navigator Freestyle SV1106 Battery Pack Replacement
Was du brauchst
  1. Shark Navigator Freestyle SV1106 Battery Pack Replacement, Battery Pack: Schritt 1, Bild 1 von 1
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 2, Bild 1 von 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 2, Bild 2 von 2
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 3, Bild 1 von 1
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 4, Bild 1 von 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 4, Bild 2 von 2
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 5, Bild 1 von 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Zachary Liu
604 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G5, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Mitglieder
10 Anleitungen geschrieben
8 Kommentare
How much is the part for the shark
sumi49 - Antwort
My Shark SV1106 doesn’t stay on very long. One episode you turn it on it immediately turns off. So what is the issue?
jklab23 - Antwort
How much is a battery pack?
ridgeite145 - Antwort
Items OrderedPrice1 of: 10.8V 3000mah Battery for Shark XBT1106N SV1110 SV1106N SV1110N SV11O6N SV116N Freestyle Navigator Cordless Stick Vacuum
Sold by: Areotek Direct (seller profile)
Condition: New
James Mayoral -
How much is a new battery pack for replacement
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 62
Insgesamt: 10,727
