Einleitung
This guide will teach you how to remove the device's fingerprint sensor.
Was du brauchst
Position the opening tool under the lid of the screen.
Slide the opening tool around the edge of the screen to loosen the adhesive.
To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab.
Lift up, removing the tab from the device.
Insert the tweezers under the metal backing of the sensor.
Lift up the backing until it is detached from the phone.
With the tweezers, grab the black connector located just above the fingerprint scanner.
Pull the connector to the right until it is detached from the phone.
