Zum Hauptinhalt wechseln
HP Envy 5660 LCD Replacement
Was du brauchst
  1. HP Envy 5660 LCD Replacement, LCD: Schritt 1, Bild 1 von 1
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: Schritt 2, Bild 1 von 2 HP Envy 5660 LCD Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: Schritt 3, Bild 1 von 3 HP Envy 5660 LCD Replacement: Schritt 3, Bild 2 von 3 HP Envy 5660 LCD Replacement: Schritt 3, Bild 3 von 3
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: Schritt 4, Bild 1 von 2 HP Envy 5660 LCD Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: Schritt 5, Bild 1 von 2 HP Envy 5660 LCD Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: Schritt 6, Bild 1 von 1
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Steakley
781 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G6, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Antwort
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 16
Insgesamt: 1,114
