Einleitung
This guide will explain the step-by-step process for replacing your RAM. Replacing the RAM could be necessary if you're laptop is not turning on.
Was du brauchst
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a nylon spudger to carefully pry the top back panel off.
Disconnect the four-pin connector and remove the top back panel from the computer.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Lift away the metal housings from each side of the laptop.
Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
Use a pair of tweezers to undo each of the four ribbon connectors.
The keyboard is now completely disconnected from the laptop and you can remove it.
First locate the RAM.
Then pull the tabs located on the left and right of the RAM outwards to release the RAM.
You can now remove the RAM and replace it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
