Zum Hauptinhalt wechseln
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
Was du brauchst
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: Schritt 1, Bild 1 von 1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: Schritt 2, Bild 1 von 1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: Schritt 3, Bild 1 von 1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: Schritt 4, Bild 1 von 1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
Abschluss
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S11-G4, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Mitglieder
10 Anleitungen geschrieben
6 Kommentare
Good job, helpful. Thanks!
Celeste Williams-Hughes - Antwort
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Antwort
Same issue. Easy fix thanks!
mark camirand - Antwort
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Antwort
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 25
Letzte 30 Tage: 138
Insgesamt: 27,880
