Zum Hauptinhalt wechseln
HP Officejet Pro 8620 Display Replacement
Was du brauchst
  1. HP Officejet Pro 8620 Display Replacement, Display: Schritt 1, Bild 1 von 2 HP Officejet Pro 8620 Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: Schritt 2, Bild 1 von 3 HP Officejet Pro 8620 Display Replacement: Schritt 2, Bild 2 von 3 HP Officejet Pro 8620 Display Replacement: Schritt 2, Bild 3 von 3
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: Schritt 3, Bild 1 von 3 HP Officejet Pro 8620 Display Replacement: Schritt 3, Bild 2 von 3 HP Officejet Pro 8620 Display Replacement: Schritt 3, Bild 3 von 3
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: Schritt 4, Bild 1 von 2 HP Officejet Pro 8620 Display Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S19-G2, Livingston Winter 2018 Mitglied von Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 4,865
