Zum Hauptinhalt wechseln
Hoover Power Path Pro Advanced Hose Replacement
Was du brauchst
  1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: Schritt 1, Bild 1 von 2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: Schritt 1, Bild 2 von 2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Hose Replacement: Schritt 2, Bild 1 von 2 Hoover Power Path Pro Advanced Hose Replacement: Schritt 2, Bild 2 von 2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Hose Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
  4. Hoover Power Path Pro Advanced Hose Replacement, Hose: Schritt 4, Bild 1 von 1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
  5. Hoover Power Path Pro Advanced Hose Replacement: Schritt 5, Bild 1 von 2 Hoover Power Path Pro Advanced Hose Replacement: Schritt 5, Bild 2 von 2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Hose Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Hose Replacement: Schritt 7, Bild 1 von 1
    • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S16-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Mitglieder
15 Anleitungen geschrieben
4 Kommentare
Where can I find this replacement hose?
Jennifer - Antwort
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - Antwort
Where can I purchase the lower hose?
Eryk H. - Antwort
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 37
Insgesamt: 4,270
