Einleitung
The hose creates a pathway for water to flow from the dirty and clean water tanks on your Hoover Power Path Pro Advanced. However, if there is a puncture in the hose, then it needs to be replaced.
Was du brauchst
Lay the cleaner down horizontally with its wheels closest to the floor.
Hold the lower brush roll with both hands and pull outwards until it is detached.
Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
Remove the brush roller.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
