Zum Hauptinhalt wechseln
Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement
  1. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement, Rubber Gasket: Schritt 1, Bild 1 von 1
    • Remove lid and place upside down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: Schritt 2, Bild 1 von 2 Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: Schritt 2, Bild 2 von 2
    • Grab the edge of the clear rubber gasket and slowly peel it off the lid.
    • Continue peeling off the gasket until it is completely detached from the lid.
Abschluss
Savannah Webb
657 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S12-G3, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Mitglieder
3 Kommentare
Am having trouble Turning the lid from Unlock to lock. The pin comes out in the back when I go to turn it from unlock to lock. Can you help me?
pclarkrob3 - Antwort
I bought the insignia pressure cooker at a garage sale but, the rubber gasket smells bad. I’ve cleaned the entire cooker but, that gasket stinks like no other
Chuck Smith - Antwort
I am having the same problem as the first comment by pclarkrob3 I am having trouble turning the lid from unlock to lock. These are really crappy instructions!!!! I have only used my pressure cooker twice so everything is still new.
Vivian Lang - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,194
