Zum Hauptinhalt wechseln
Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement
Was du brauchst
  1. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: Schritt 1, Bild 1 von 2 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: Schritt 1, Bild 2 von 2
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 2, Bild 1 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 2, Bild 2 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 2, Bild 3 von 3
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
  3. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 3, Bild 1 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 3, Bild 2 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
  4. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 4, Bild 1 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 4, Bild 2 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 4, Bild 3 von 3
    • Remove the two screws on the left side of the brush.
  5. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 5, Bild 1 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 5, Bild 2 von 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: Schritt 5, Bild 3 von 3
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
  6. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Vacuum Belt: Schritt 6, Bild 1 von 1
    • Removal of the brush will also remove the belt.
Abschluss
Erik Ingels
193 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S12-G4, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G4, Banghart Winter 2018
CPSU-BANGHART-W18S12G4
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 759
