Einleitung
This is the perfect guide if you're looking to replace stock speakers with a nicer set, or if you've blown out your current speakers in your Mazda 6. Speakers are fairly easy to replace as long as you aren't completely rewiring the system.
Was du brauchst
Pop open the hood and locate the battery.
Loosen the bolt on the positive terminal with the 10mm wrench.
Pull up and detach the terminal to disrupt power flow.
Pry open the screw cover on the inside of the handle with the small flathead screwdriver.
Unscrew the handle with the phillips screwdriver.
Pull the handle cover down and out of its pocket.
Slide the cover to the right off the handle.
Detach the tab on the back of the locking mechanism to completely remove the cover.
Peel off the rubber insert in the inner arm rest.
Unscrew the inner arm rest panel with the phillips screwdriver. This screw is holding the arm rest panel together.
Pry the power window switch case out of the arm rest with your flathead screwdriver.
Detach all tabs on the back of the switch case to remove completely.
Use a flathead screwdriver to press the clip holding the light from the back of the door and pull the lightbulb out.
Unscrew four bolts holding the speaker with the ratchet.
Pull out the speaker.
Detach the connector in the back.
Splice the wires from the door to the new speaker's wires making sure to connect the correct wire polarity. (The small connector wire from the speaker is positive.)
Cover and crimp the wires with the butt-end connectors.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
