Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5100 Hard Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C55-A5100 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 902
