Einleitung
This guide demonstrates how to remove the keyboard from an Alienware M18x Laptop.
Was du brauchst
Turn the computer over.
Slide the battery latch over and lift the battery out.
Turn the laptop right-side up, and open the laptop.
Use the plastic pryer tool to loosen the flat piece surrounding the keys by gently prying it upwards from the laptop's base.
Make sure to go around the entire perimeter of the piece to loosen all areas of it.
The piece is now free from its fastenings to the base of the laptop, and can be lifted off.
Gently remove the power cable with your hands or with the help of a prying tool.
The keyboard's 3mm fastening screws are now exposed and can be removed with a J000 screwdriver.
As before, the keyboard is now unfastened but still connected to the base via cables.
Flip the keyboard over towards the edge of the laptop to expose the locations of the connectors. Avoid tugging on the cables when you do this.
The left section of the keyboard is connected by a single screw and two connector cables.
Remove the 4mm screw with a J000 screwdriver.
Remove the connecting cables with a prying bar.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
