Zum Hauptinhalt wechseln
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: Schritt 2, Bild 1 von 1
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: Schritt 3, Bild 1 von 2 Fujifilm FinePix Z1 Battery Replacement: Schritt 3, Bild 2 von 2
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: Schritt 4, Bild 1 von 1
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery and replace with a new one.
Abschluss
Carra
533 Reputation
4 Anleitungen geschrieben
Baylor, Team S2-G4, Johnson Spring 2018 Mitglied von Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 683
