Zum Hauptinhalt wechseln
HP Envy x360 15-u473cl Touch Screen Replacement
Was du brauchst
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: Schritt 1, Bild 1 von 2 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: Schritt 1, Bild 2 von 2
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 2, Bild 1 von 1
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 4, Bild 1 von 2 HP Envy x360 15-u473cl Touch Screen Replacement: Schritt 4, Bild 2 von 2
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 46
Insgesamt: 12,753
