Zum Hauptinhalt wechseln
Dell Inspiron 15-5552 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15-5552 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 2 Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the two 6 mm screws from the back panel.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  6. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Using a spudger, lightly lift the RAM cover up and at an angle, away from the computer.
  7. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 6 mm JIS #0 screws from the hard drive.
  8. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Lift hard drive out of the computer slightly.
    • Be careful not to tear the ribbon that attaches the hard drive to the computer when lifting it.
  9. Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 15-5552 Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Using two fingers, grab the black connector on the ribbon, and pull until detached.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 405
