Zum Hauptinhalt wechseln
Dell Alienware 13 R3 Coin-Cell Battery Replacement
Was du brauchst
  1. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Loosen the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Pry the Base Cover: Schritt 2, Bild 1 von 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Lift the Base Cover: Schritt 3, Bild 1 von 1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Disconnect the Battery Cable: Schritt 4, Bild 1 von 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Slide the Tabs: Schritt 7, Bild 1 von 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Tighten the Five Captive Screws: Schritt 8, Bild 1 von 1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screw: Schritt 9, Bild 1 von 1
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  8. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Lift and Slide the Solid-State Drive: Schritt 10, Bild 1 von 1
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  9. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Press the Memory Module: Schritt 12, Bild 1 von 1
    • Press the memory module down until it clicks into place.
  10. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screws: Schritt 13, Bild 1 von 1
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  11. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Using a Plastic Scribe: Schritt 14, Bild 1 von 1
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  12. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Sliding the Rear-I/O: Schritt 16, Bild 1 von 1
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  13. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screws: Schritt 18, Bild 1 von 1
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  14. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screw: Schritt 19, Bild 1 von 1
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  15. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Two Screws: Schritt 20, Bild 1 von 1
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  16. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Lift the Computer Base: Schritt 21, Bild 1 von 1
    • Lift the computer base from the palm-rest assembly.
  17. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Align the Screw Holes: Schritt 22, Bild 1 von 1
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  18. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: Schritt 26, Bild 1 von 1
    • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from the system board.
  19. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Peeling the Coin-Cell Battery: Schritt 27, Bild 1 von 1
    • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  20. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Adhere the Coin-Cell Battery: Schritt 28, Bild 1 von 1
    • Adhere the NEW coin-cell battery to the palm-rest assembly.
    • Connect the coin-cell battery cable to the system board.
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 1,340
