Zum Hauptinhalt wechseln
Razer Naga Expert MMO Top Plastic Shell Replacement
Was du brauchst
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: Schritt 1, Bild 1 von 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: Schritt 4, Bild 1 von 1
    • Lightly pull the two plastic sides of the mouse to remove them.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Gianni Conti
461 Reputation
2 Anleitungen geschrieben
2 Kommentare
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Antwort
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 1,838
