Zum Hauptinhalt wechseln
Dell Alienware 14 Base Cover Replacement
Was du brauchst
  1. Dell Alienware 14 Base Cover Replacement, Close the Display: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Base Cover Replacement, Remove the Screws: Schritt 2, Bild 1 von 2 Dell Alienware 14 Base Cover Replacement, Remove the Screws: Schritt 2, Bild 2 von 2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Base Cover Replacement, Slide and Lift the Base Cover: Schritt 3, Bild 1 von 1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Base Cover Replacement, Align the Tabs: Schritt 4, Bild 1 von 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Base Cover Replacement, Replace the Screws: Schritt 5, Bild 1 von 1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Base Cover Replacement, Turn the Computer Over: Schritt 6, Bild 1 von 1
    • Turn the computer over and open the display.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 425
