Einleitung
Trip over your power cord? Use this guide to replace your DC-in board.
Was du brauchst
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Use your fingernails or the tip of a spudger to separate the ZIF cable lock from its socket.
Use the tip of a spudger to remove the piece of foam tape from the channel on the side of the left speaker.
De-route the cables from the channel in the left speaker.
Remove the single T8 Torx screw securing the left speaker to the lower case.
Lift the left speaker from its rear edge and maneuver it out of the lower case, minding the cables sitting in the channel near the front edge of the left speaker.
Set the speaker next to the lower case.
Remove the two T8 Torx screws securing the DC-in board to the lower case.
New line.
Pull the DC-in board away from the side of the lower case to separate the ports from their bezel.
Lift the DC-in board out of the lower case.
