Zum Hauptinhalt wechseln
Dell Inspiron 15-5552 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15-5552 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Battery Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-5552 Battery Replacement: Schritt 4, Bild 2 von 2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 237
