Zum Hauptinhalt wechseln
Dell Alienware 14 Keyboard Replacement
Was du brauchst
  1. Dell Alienware 14 Keyboard Replacement, Close the Display: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 2, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 2, Bild 2 von 2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Keyboard Replacement, Slide and Lift the Base Cover: Schritt 3, Bild 1 von 1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Keyboard Replacement, Align the Tabs: Schritt 4, Bild 1 von 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Keyboard Replacement, Replace the Screws: Schritt 5, Bild 1 von 1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Keyboard Replacement, Turn the Computer Over: Schritt 6, Bild 1 von 1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Keyboard Replacement, Disconnecting the Battery Cable: Schritt 7, Bild 1 von 1
  8. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Keyboard Replacement, Using the Battery Cable: Schritt 9, Bild 1 von 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Keyboard Replacement, Turn the Computer Over: Schritt 10, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Keyboard Replacement, The Power Button: Schritt 11, Bild 1 von 1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Keyboard Replacement, Align the Tabs: Schritt 13, Bild 1 von 1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Keyboard Replacement, Align the Screw Holes: Schritt 14, Bild 1 von 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Keyboard Replacement, Replace the Screws: Schritt 15, Bild 1 von 1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Keyboard Replacement, Connect the Battery Cable: Schritt 16, Bild 1 von 1
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 17, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 17, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Keyboard Replacement, Lifting the Secondary Hard-Drive: Schritt 18, Bild 1 von 3 Dell Alienware 14 Keyboard Replacement, Lifting the Secondary Hard-Drive: Schritt 18, Bild 2 von 3 Dell Alienware 14 Keyboard Replacement, Lifting the Secondary Hard-Drive: Schritt 18, Bild 3 von 3
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Keyboard Replacement, Lifting the Hard Drive: Schritt 19, Bild 1 von 1
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Keyboard Replacement, Turn the Assembly Over: Schritt 20, Bild 1 von 1
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Keyboard Replacement, Remove the Screw: Schritt 21, Bild 1 von 1
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 22, Bild 1 von 1
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Keyboard Replacement, Slide and Lift the Hard-Drive: Schritt 23, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Slide and Lift the Hard-Drive: Schritt 23, Bild 2 von 2
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Keyboard Replacement, Disconnect the Interposer: Schritt 24, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Disconnect the Interposer: Schritt 24, Bild 2 von 2
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Keyboard Replacement, Connect the Interposer: Schritt 25, Bild 1 von 1
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Keyboard Replacement, Placing the Secondary Hard-Drive: Schritt 26, Bild 1 von 1
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Keyboard Replacement, Align the Screw Holes: Schritt 27, Bild 1 von 1
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Keyboard Replacement, Replace the Screws: Schritt 28, Bild 1 von 1
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Keyboard Replacement, Align the Screw Hole: Schritt 29, Bild 1 von 1
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Keyboard Replacement, Replace the Screw: Schritt 30, Bild 1 von 1
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Keyboard Replacement, Turn the Hard-Drive Assembly Over: Schritt 31, Bild 1 von 1
  31. Dell Alienware 14 Keyboard Replacement, Slide the Hard-Drive Cable: Schritt 32, Bild 1 von 1
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Keyboard Replacement, Align the Screw Holes: Schritt 33, Bild 1 von 1
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  33. Dell Alienware 14 Keyboard Replacement, Disconnecting the Status-Light Board Cable: Schritt 35, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Disconnecting the Status-Light Board Cable: Schritt 35, Bild 2 von 2
    • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
  34. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 36, Bild 1 von 1
    • Remove the screws that secure the palm -rest assembly to the computer base.
  35. Dell Alienware 14 Keyboard Replacement, Turn the Computer Over: Schritt 37, Bild 1 von 1
  36. Dell Alienware 14 Keyboard Replacement, Pry the Palm-Rest Assembly: Schritt 38, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Pry the Palm-Rest Assembly: Schritt 38, Bild 2 von 2
    • Using a plastic scribe, pry the palm-rest assembly from the computer base.
  37. Dell Alienware 14 Keyboard Replacement, Lift the Palm-Rest Assembly: Schritt 39, Bild 1 von 1
    • Carefully lift the palm-rest assembly and turn it over.
  38. Dell Alienware 14 Keyboard Replacement, Release the Connector Latches: Schritt 40, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Release the Connector Latches: Schritt 40, Bild 2 von 2
    • Release the connector latches to disconnect the flexi-cable from the system board.
    • Connect the flexi-cable to the connector on the system board.
  39. Dell Alienware 14 Keyboard Replacement, Turn the Palm-Rest Assembly: Schritt 44, Bild 1 von 1
    • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
  40. Dell Alienware 14 Keyboard Replacement, Close the Display: Schritt 46, Bild 1 von 1
  41. Dell Alienware 14 Keyboard Replacement, Replace the Screws: Schritt 47, Bild 1 von 1
    • Replace the screws that secure the palm-rest assembly to the computer base.
  42. Dell Alienware 14 Keyboard Replacement, Slide the Status-Light Board Cable: Schritt 48, Bild 1 von 1
    • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
  43. Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latch: Schritt 49, Bild 1 von 3 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latch: Schritt 49, Bild 2 von 3 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latch: Schritt 49, Bild 3 von 3
    • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Lift the connector latch and disconnect the power-button board cable from the status-light board connector.
  44. Dell Alienware 14 Keyboard Replacement, Peeling the Power-Button Board Cable: Schritt 50, Bild 1 von 1
    • Peel the power-button board cable off the keyboard bracket.
  45. Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latches: Schritt 51, Bild 1 von 3 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latches: Schritt 51, Bild 2 von 3 Dell Alienware 14 Keyboard Replacement, Lifting the Connector Latches: Schritt 51, Bild 3 von 3
    • Lift the connector latches and disconnect the keyboard cable and keyboard-backlight cable from the keyboard-board connectors.
  46. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 52, Bild 1 von 1
    • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
  47. Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard Bracket: Schritt 53, Bild 1 von 1
    • Lift the keyboard bracket at an angle and release it from the tabs on the palm-rest assembly.
  48. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: Schritt 54, Bild 1 von 1
    • Slide the keyboard cable and keyboard-backlight cable through the keyboard bracket.
  49. Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard Bracket: Schritt 55, Bild 1 von 1
    • Lift the keyboard bracket off the keyboard.
  50. Dell Alienware 14 Keyboard Replacement, Remove the Screws: Schritt 56, Bild 1 von 1
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  51. Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard: Schritt 57, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Lifting the Keyboard: Schritt 57, Bild 2 von 2
    • Lift the keyboard and release it from the tabs on the palm-rest assembly.
  52. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard: Schritt 58, Bild 1 von 1
    • Slide the NEW keyboard under the tabs of the palm-rest assembly and align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
  53. Dell Alienware 14 Keyboard Replacement, Replace the Screws: Schritt 59, Bild 1 von 1
    • Replace the screws that secure the keyboard to the palm-rest assembly.
  54. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: Schritt 60, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: Schritt 60, Bild 2 von 2
  55. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Bracket: Schritt 61, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Bracket: Schritt 61, Bild 2 von 2
    • Slide the keyboard bracket under the tabs on the palm-rest assembly and align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  56. Dell Alienware 14 Keyboard Replacement, Replace the Screws: Schritt 62, Bild 1 von 1
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
  57. Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: Schritt 63, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Sliding the Keyboard Cable: Schritt 63, Bild 2 von 2
    • Slide the keyboard cable and keyboard-backlight cable into the keyboard-board connectors and press down on the connector latches to secure the cables.
  58. Dell Alienware 14 Keyboard Replacement, Routing the Power-Button Cable: Schritt 64, Bild 1 von 1
    • Route the power-button board cable on the keyboard bracket and adhere the cable to the keyboard bracket.
  59. Dell Alienware 14 Keyboard Replacement, Sliding the Power-Button Board Cable: Schritt 65, Bild 1 von 2 Dell Alienware 14 Keyboard Replacement, Sliding the Power-Button Board Cable: Schritt 65, Bild 2 von 2
    • Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 1,993
