Zum Hauptinhalt wechseln
Dell Alienware 14 Display Assembly Replacement
Was du brauchst
  1. Dell Alienware 14 Display Assembly Replacement, Close the Display: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 2, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 2, Bild 2 von 2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Display Assembly Replacement, Slide and Lift the Base Cover: Schritt 3, Bild 1 von 1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Display Assembly Replacement, Align the Tabs: Schritt 4, Bild 1 von 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Display Assembly Replacement, Replace the Screws: Schritt 5, Bild 1 von 1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Display Assembly Replacement, Turn the Computer Over: Schritt 6, Bild 1 von 1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Display Assembly Replacement, Disconnecting the Battery Cable: Schritt 7, Bild 1 von 1
  8. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Display Assembly Replacement, Using the Battery Cable: Schritt 9, Bild 1 von 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Display Assembly Replacement, Turn the Computer Over: Schritt 10, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Display Assembly Replacement, The Power Button: Schritt 11, Bild 1 von 1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Display Assembly Replacement, Align the Tabs: Schritt 13, Bild 1 von 1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Display Assembly Replacement, Align the Screw Holes: Schritt 14, Bild 1 von 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Display Assembly Replacement, Replace the Screws: Schritt 15, Bild 1 von 1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Display Assembly Replacement, Connect the Battery Cable: Schritt 16, Bild 1 von 1
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 17, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 17, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Dell Alienware 14 Display Assembly Replacement, Lifting the Secondary Hard-Drive: Schritt 18, Bild 1 von 3 Dell Alienware 14 Display Assembly Replacement, Lifting the Secondary Hard-Drive: Schritt 18, Bild 2 von 3 Dell Alienware 14 Display Assembly Replacement, Lifting the Secondary Hard-Drive: Schritt 18, Bild 3 von 3
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Dell Alienware 14 Display Assembly Replacement, Lifting the Hard Drive: Schritt 19, Bild 1 von 1
    • Lift the secondary hard-drive assembly off the computer base.
  19. Dell Alienware 14 Display Assembly Replacement, Turn the Assembly Over: Schritt 20, Bild 1 von 1
    • Turn the secondary hard-drive assembly over.
  20. Dell Alienware 14 Display Assembly Replacement, Remove the Screw: Schritt 21, Bild 1 von 1
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  21. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 22, Bild 1 von 1
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  22. Dell Alienware 14 Display Assembly Replacement, Slide and Lift the Hard-Drive: Schritt 23, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Slide and Lift the Hard-Drive: Schritt 23, Bild 2 von 2
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  23. Dell Alienware 14 Display Assembly Replacement, Disconnect the Interposer: Schritt 24, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Disconnect the Interposer: Schritt 24, Bild 2 von 2
    • Disconnect the interposer from the secondary hard-drive connector.
  24. Dell Alienware 14 Display Assembly Replacement, Connect the Interposer: Schritt 25, Bild 1 von 1
    • Connect the interposer to the secondary hard-drive connector.
  25. Dell Alienware 14 Display Assembly Replacement, Placing the Secondary Hard-Drive: Schritt 26, Bild 1 von 1
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  26. Dell Alienware 14 Display Assembly Replacement, Align the Screw Holes: Schritt 27, Bild 1 von 1
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  27. Dell Alienware 14 Display Assembly Replacement, Replace the Screws: Schritt 28, Bild 1 von 1
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  28. Dell Alienware 14 Display Assembly Replacement, Align the Screw Hole: Schritt 29, Bild 1 von 1
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  29. Dell Alienware 14 Display Assembly Replacement, Replace the Screw: Schritt 30, Bild 1 von 1
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  30. Dell Alienware 14 Display Assembly Replacement, Turn the Hard-Drive Assembly Over: Schritt 31, Bild 1 von 1
  31. Dell Alienware 14 Display Assembly Replacement, Slide the Hard-Drive Cable: Schritt 32, Bild 1 von 1
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  32. Dell Alienware 14 Display Assembly Replacement, Align the Screw Holes: Schritt 33, Bild 1 von 1
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  33. Dell Alienware 14 Display Assembly Replacement, Disconnecting the Status-Light Board Cable: Schritt 35, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Disconnecting the Status-Light Board Cable: Schritt 35, Bild 2 von 2
    • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
  34. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 36, Bild 1 von 1
    • Remove the screws that secure the palm -rest assembly to the computer base.
  35. Dell Alienware 14 Display Assembly Replacement, Turn the Computer Over: Schritt 37, Bild 1 von 1
  36. Dell Alienware 14 Display Assembly Replacement, Pry the Palm-Rest Assembly: Schritt 38, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Pry the Palm-Rest Assembly: Schritt 38, Bild 2 von 2
    • Using a plastic scribe, pry the palm-rest assembly from the computer base.
  37. Dell Alienware 14 Display Assembly Replacement, Lift the Palm-Rest Assembly: Schritt 39, Bild 1 von 1
    • Carefully lift the palm-rest assembly and turn it over.
  38. Dell Alienware 14 Display Assembly Replacement, Release the Connector Latches: Schritt 40, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Release the Connector Latches: Schritt 40, Bild 2 von 2
    • Release the connector latches to disconnect the flexi-cable from the system board.
    • Connect the flexi-cable to the connector on the system board.
  39. Dell Alienware 14 Display Assembly Replacement, Turn the Palm-Rest Assembly: Schritt 44, Bild 1 von 1
    • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
  40. Dell Alienware 14 Display Assembly Replacement, Close the Display: Schritt 46, Bild 1 von 1
  41. Dell Alienware 14 Display Assembly Replacement, Replace the Screws: Schritt 47, Bild 1 von 1
    • Replace the screws that secure the palm-rest assembly to the computer base.
  42. Dell Alienware 14 Display Assembly Replacement, Slide the Status-Light Board Cable: Schritt 48, Bild 1 von 1
    • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
  43. Dell Alienware 14 Display Assembly Replacement, Close the Display: Schritt 49, Bild 1 von 1
  44. Dell Alienware 14 Display Assembly Replacement, Disconnecting the Display: Schritt 50, Bild 1 von 1
    • Disconnect the display and camera cables from the system-board connectors.
  45. Dell Alienware 14 Display Assembly Replacement, Disconnect the Antenna Cables: Schritt 51, Bild 1 von 2 Dell Alienware 14 Display Assembly Replacement, Disconnect the Antenna Cables: Schritt 51, Bild 2 von 2
    • Disconnect the antenna cables from the wireless mini-card.
  46. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 52, Bild 1 von 1
    • Remove the screws that secure the display assembly to the computer base.
  47. Dell Alienware 14 Display Assembly Replacement, Turn the Computer Over: Schritt 53, Bild 1 von 1
  48. Dell Alienware 14 Display Assembly Replacement, Remove the Cables: Schritt 54, Bild 1 von 1
    • Remove the display, camera, and antenna cables from the slots on the computer base.
  49. Dell Alienware 14 Display Assembly Replacement, Note the Cable-Routing: Schritt 55, Bild 1 von 1
    • Note the display, camera and antenna cable-routing and remove the cables from their routing guides.
  50. Dell Alienware 14 Display Assembly Replacement, Slide the Cables: Schritt 56, Bild 1 von 1
    • Slide the cables through the slots on the computer base.
  51. Dell Alienware 14 Display Assembly Replacement, Remove the Screws: Schritt 57, Bild 1 von 1
  52. Dell Alienware 14 Display Assembly Replacement, Lifting the Display Assembly: Schritt 58, Bild 1 von 1
    • Lift the display assembly off the computer base.
  53. Dell Alienware 14 Display Assembly Replacement, Align the Screw Holes: Schritt 59, Bild 1 von 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  54. Dell Alienware 14 Display Assembly Replacement, Replace the Screws: Schritt 60, Bild 1 von 1
    • Replace the screws that secure the display assembly to the computer base.
  55. Dell Alienware 14 Display Assembly Replacement, Slide the Cables: Schritt 61, Bild 1 von 1
  56. Dell Alienware 14 Display Assembly Replacement, Close the Display: Schritt 62, Bild 1 von 1
  57. Dell Alienware 14 Display Assembly Replacement, Route the Cables: Schritt 63, Bild 1 von 1
    • Route the display, camera, and antenna cables through the routing guides.
  58. Dell Alienware 14 Display Assembly Replacement, Replace the Screws: Schritt 64, Bild 1 von 1
  59. Dell Alienware 14 Display Assembly Replacement, Connecting the Cables: Schritt 65, Bild 1 von 1
    • Connect the display and camera cables to the system-board connectors.
  60. Dell Alienware 14 Display Assembly Replacement, Connecting the Antenna Cables: Schritt 66, Bild 1 von 1
    • Connect the antenna cables to the wireless mini-card.
Abschluss
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 500
