Zum Hauptinhalt wechseln
HP 15-ac121dx CD Compartment Replacement
Was du brauchst
  1. HP 15-ac121dx CD Compartment Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx CD Compartment Replacement: Schritt 2, Bild 1 von 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx CD Compartment Replacement: Schritt 3, Bild 1 von 2 HP 15-ac121dx CD Compartment Replacement: Schritt 3, Bild 2 von 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx CD Compartment Replacement: Schritt 4, Bild 1 von 2 HP 15-ac121dx CD Compartment Replacement: Schritt 4, Bild 2 von 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx CD Compartment Replacement, Back Panel: Schritt 5, Bild 1 von 3 HP 15-ac121dx CD Compartment Replacement, Back Panel: Schritt 5, Bild 2 von 3 HP 15-ac121dx CD Compartment Replacement, Back Panel: Schritt 5, Bild 3 von 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx CD Compartment Replacement: Schritt 6, Bild 1 von 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx CD Compartment Replacement: Schritt 7, Bild 1 von 3 HP 15-ac121dx CD Compartment Replacement: Schritt 7, Bild 2 von 3 HP 15-ac121dx CD Compartment Replacement: Schritt 7, Bild 3 von 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx CD Compartment Replacement, CD Compartment: Schritt 8, Bild 1 von 3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: Schritt 8, Bild 2 von 3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: Schritt 8, Bild 3 von 3
    • Locate the CD Compartment as shown and gently slide it out.
Abschluss
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ashton Martin
459 Reputation
2 Anleitungen geschrieben
Baylor, Team S1-G2, Johnson Spring 2018 Mitglied von Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 406
