Einleitung
Are you experiencing issues powering on your flip book? Is it losing it's charge very quickly? If so, this guide will help you replace a faulty battery in a few easy steps.
Was du brauchst
Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
2 weitere Nutzer:innen haben diese Anleitung absolviert.
