Zum Hauptinhalt wechseln
Asus Transformer Flip Book TP200S WiFi Card Replacement
Was du brauchst
  1. Asus Transformer Flip Book TP200S WiFi Card Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Transformer Flip Book TP200S WiFi Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 4, Bild 1 von 2 Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 4, Bild 2 von 2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
  5. Asus Transformer Flip Book TP200S WiFi Card Replacement, WiFi Card: Schritt 5, Bild 1 von 1
    • The WiFi card will be covered by tape and attached to the motherboard.
    • Remove the tape from the WiFi card.
  6. Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 6, Bild 1 von 3 Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 6, Bild 2 von 3 Asus Transformer Flip Book TP200S WiFi Card Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the WiFi card with a JIS #000 screwdriver.
    • Remove the motherboard connection from the WiFi card with tweezers.
    • Pull out the WiFi card.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S17-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 781
