Zum Hauptinhalt wechseln
Protocol Vento Motor Replacement
Was du brauchst
  1. Protocol Vento Motor Replacement, Battery: Schritt 1, Bild 1 von 1
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: Schritt 2, Bild 1 von 1
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: Schritt 3, Bild 1 von 1
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: Schritt 4, Bild 1 von 2 Protocol Vento Motor Replacement: Schritt 4, Bild 2 von 2
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: Schritt 5, Bild 1 von 1
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: Schritt 6, Bild 1 von 2 Protocol Vento Motor Replacement: Schritt 6, Bild 2 von 2
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: Schritt 7, Bild 1 von 2 Protocol Vento Motor Replacement: Schritt 7, Bild 2 von 2
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: Schritt 8, Bild 1 von 2 Protocol Vento Motor Replacement: Schritt 8, Bild 2 von 2
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G2, Leahy Spring 2018 Mitglied von USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 647
