Zum Hauptinhalt wechseln
Razer Naga Expert MMO Scroll Wheel Replacement
Was du brauchst
  1. Razer Naga Expert MMO Scroll Wheel Replacement, Top Plastic Shell: Schritt 1, Bild 1 von 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 4, Bild 1 von 1
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Scroll Wheel Replacement, Scroll Wheel: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
  6. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 6, Bild 1 von 1
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 7, Bild 1 von 1
    • Slide the chip out of the scroll wheel.
  8. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 8, Bild 1 von 2 Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 8, Bild 2 von 2
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
  9. Razer Naga Expert MMO Scroll Wheel Replacement: Schritt 9, Bild 1 von 1
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 4,454
