Zum Hauptinhalt wechseln
Dell Inspiron 11-3164 Screen Replacement
Was du brauchst
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3164 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
Abschluss
USF Tampa, Team S6-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 156
