Zum Hauptinhalt wechseln
Repairing Nintendo 64 Controller Joystick Replacement
Was du brauchst
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: Schritt 1, Bild 1 von 3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: Schritt 1, Bild 2 von 3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: Schritt 1, Bild 3 von 3
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: Schritt 2, Bild 1 von 3 Repairing Nintendo 64 Controller Joystick Replacement: Schritt 2, Bild 2 von 3 Repairing Nintendo 64 Controller Joystick Replacement: Schritt 2, Bild 3 von 3
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: Schritt 3, Bild 1 von 3 Repairing Nintendo 64 Controller Joystick Replacement: Schritt 3, Bild 2 von 3 Repairing Nintendo 64 Controller Joystick Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
Abschluss
Test out your controller! It should be feeling like new.
33 weitere Nutzer:innen haben diese Anleitung absolviert.
Zillatron
1.511 Reputation
1 Anleitung geschrieben
2 Kommentare
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - Antwort
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 50
Letzte 30 Tage: 216
Insgesamt: 44,413
