Zum Hauptinhalt wechseln
Dell Inspiron 15-3531 Fan Replacement
Was du brauchst
  1. Dell Inspiron 15-3531 Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Fan Replacement, Motherboard: Schritt 2, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement, Motherboard: Schritt 2, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel open with the spudger.
  3. Dell Inspiron 15-3531 Fan Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 3, Bild 3 von 3
    • Remove the memory card by pulling apart the latches holding it in place.
  4. Dell Inspiron 15-3531 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the nine 8.65mm screws holding the backplate to the laptop using the PH0 head screwdriver.
    • Remove the four 1.22 mm screws holding the backplate to the laptop using the PH0 head screwdriver.
  5. Dell Inspiron 15-3531 Fan Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 5, Bild 3 von 3
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard using a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting out the keyboard because there is a cable connecting it to the laptop.
  6. Dell Inspiron 15-3531 Fan Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 6, Bild 3 von 3
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
  7. Dell Inspiron 15-3531 Fan Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 7, Bild 3 von 3
    • Disengage both antenna (black and white) cables by lifting them up using the spudger.
    • Unscrew the one 8.65 mm screw holding the wireless card.
    • Remove the wireless card.
  8. Dell Inspiron 15-3531 Fan Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 15-3531 Fan Replacement: Schritt 8, Bild 2 von 2
    • Lift the locking tab with the spudger and pull the cable form the locking tab.
    • Repeat with the second locking tab.
  9. Dell Inspiron 15-3531 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the four 8.65 mm screws underneath the keyboard plate.
    • Remove the three 1.22 mm small screws underneath the keyboard plate.
  10. Dell Inspiron 15-3531 Fan Replacement: Schritt 10, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 10, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 10, Bild 3 von 3
    • Separate the palmrest from the base of the laptop using the spudger to loosen the palmrest along the edges.
    • Make sure to remove all the screws, especially the inconspicuous 8.65 mm screw next to the hard drive.
  11. Dell Inspiron 15-3531 Fan Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron 15-3531 Fan Replacement: Schritt 11, Bild 3 von 3
    • Remove the cables on the upper left side of the laptop using flat tweezers.
    • Remove the cable from the upper right hand corner.
  12. Dell Inspiron 15-3531 Fan Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 15-3531 Fan Replacement: Schritt 12, Bild 2 von 2
    • Remove the speaker cable.
    • Remove cable on the right-hand side.
  13. Dell Inspiron 15-3531 Fan Replacement: Schritt 13, Bild 1 von 1
    • Unscrew the one 8.65 mm screw holding the motherboard in place with a PH0 size head screwdriver.
    • Remove the motherboard.
  14. Dell Inspiron 15-3531 Fan Replacement, Fan: Schritt 14, Bild 1 von 2 Dell Inspiron 15-3531 Fan Replacement, Fan: Schritt 14, Bild 2 von 2
    • Turn over the motherboard.
    • Disconnect the fan power cable.
    • Remove the 8.65 mm screw holding the fan casing to the laptop frame using a PH0 head screwdriver.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kody Dahlke
730 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G5, Leahy Spring 2018 Mitglied von USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 738
